Date/Time: Fri, 14 Mar 2025 19:11:06 +0000
delays in data delivery
View Count: 478
[2022-06-29 10:30:56] |
Piotr Kucharski - Posts: 3 |
hello I have the Sierra 2383 version, changed the package to 10 and I am having trouble delivering data, there is a 10-15 minute delay. Where is the problem ? and how to change it to good settings. I tried to do according to the previous instructions but it still doesn't work. I will be grateful for quick information. |
[2022-06-29 11:15:53] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above completely before making a further inquiry regarding real-time *futures* data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-29 11:22:48] |
I have an AMP account and use CQG data
[2022-06-29 12:12:01] |
Complete the agreements and activate the exchanges you need from here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliNASDAQ Let us know if you need any help with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
