Date/Time: Fri, 14 Mar 2025 19:06:41 +0000
Market Depth recordings after Deleting all data and download
View Count: 504
[2022-06-28 21:50:25]
User589284 - Posts: 6
Hi.
Couldn't find an answer in the Support board, so:
Sometimes due to Data issues, per your recommendations I initiate the "Deleting All Data And Download" function.
But this means also removing all the Market Depth recording that was accumulated so far.
Can you kindly advise how can I save / avoid losing the recorded data of Market Depth in these cases?
Thank you
[2022-06-29 14:16:51]
John - SC Support - Posts: 38669
Selecting "Delete All Data and Download" does NOT delete the Market Depth data files. So you should not have any issue with the Market Depth showing up immediately after the data is redownloaded.
