Date/Time: Fri, 26 Apr 2024 08:34:51 +0000
price increments
View Count: 2113
[2013-04-27 01:46:53] |
There were some additional changes to this to make sure the scaling works like before. The current version is 967. Otherwise, we are not aware of any problems. In any case, what you just need to do is set the Scale Increment to 1: http://www.sierrachart.com/index.php?l=doc/helpdetails40.html Not certain what you mean about getting irritated after every upgrade as if somehow there is a problem with each upgrade. Rather than making this particular comment, specifically let us know what you are referring to. We continue to make the software more reliable, better organized and add necessary features. And also keep in mind some issues could be due to external services an external components which we have no control over. Some of this is discussed in help topic 76 here: http://www.sierrachart.com/index.php?l=doc/helpdetails76.html For example, we have no control over the market data feed, or the backend trading functionality. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-27 01:49:30
