Date/Time: Fri, 14 Mar 2025 19:06:42 +0000
Trade DOM Bid & Ask Market Depth Pulling/Stacking
View Count: 478
[2022-06-28 16:22:58] |
countryboy92 - Posts: 91 |
The total for each the Bid and Ask column shows up at the end (bottom or top) of the last order, but often I cannot see it on the screen without scrolling up or down. Is there a way to have the total show up right below the column header label?
[2022-06-28 16:58:20] |
John - SC Support - Posts: 38669 |
There is not a way to do exactly what you want. The best option to be able to see the totals is to use the DOM Graph (Chart >> Chart Settings >> Market Depth) and just show the Only Single Level with Greatest Volume along with the Volume Totals and Percentages. It does not guarantee that the numbers will be closer to the current price, but generally they are. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
