Date/Time: Sat, 30 Nov 2024 06:41:18 +0000
Stop loss as a market order
View Count: 656
[2022-06-28 15:05:47] |
User449884 - Posts: 155 |
How do i switch to have my stop loos in my bracket orders to be market orders?
[2022-06-28 15:16:00] |
We are not understanding your question. If you change your Stop to a Market order, then the stop will be filled immediately and close your position. If your trading service will allow you to do it, then you can just move the Stop to a price Above/Below (depending on the position type of Long/Short) the current price and have it fill that way. But, in general, if you are wanting to close your position immediately, then you should use the "Flatten and Cancel" command. Refer to the following: Basic Trading and the Trade Window: Main/C >> Flatten (Flatten and Cancel) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-28 15:20:39] |
i want for the order to be filled at market when the price hits it. By default i think they are limit orders and volatile days like today, i got run over on my stop but never taken out of my position
[2022-06-28 16:05:49] |
As long as you are using a Standard Stop, then it is converted to a market order when the price touches it. Refer to the following: Order Types: Stop There is a separate Stop-Limit, which is described at the following: Order Types: Stop-Limit You would have to check and see which type you were actually using for your order. If you have an issue with how the order filled, then you would need to ask your broker. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-12 15:16:40] |
IAMSPARTACUS - Posts: 34 |
Hi. My OCO is set to stop, but it still filled as Stop-Limit. How do I fix that? |
[2022-12-12 18:26:40] |
If this is with the CME Group, then that is something that the exchange is doing. Refer to the following: Order Types: Stop Orders on the CME For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
