Date/Time: Tue, 15 Sep 2026 03:12:16 +0000
Number Bars or Scale setting
View Count: 600
[2022-06-28 13:28:04]
SpearChucker - Posts: 116
I seem to have a setting wrong on this chart, and I can't find where to change it. The Numbers Bars shows empty gaps for some prices. I would like to see them for all prices. I've included some properties settings screen caps where I've tried changing settings, with no luck. I also don't see a setting in the Number Bars settings (like Volume by Price) that changes the Ticks per Volume Bar. What am I missing? Thanks.
imageNB.jpg / V - Attached On 2022-06-28 13:27:43 UTC - Size: 178.34 KB - 220 views
[2022-06-28 14:24:52]
John - SC Support - Posts: 47889
Check your setting for Chart >> Chart Settings >> Chart Data >> Volume at Price Multiplier. Make sure both the Intraday and Historical settings are set to 1.
