Date/Time: Sat, 15 Mar 2025 07:56:00 +0000
All tools condensed on one price after re-opening SC
View Count: 446
[2022-06-28 05:44:02]
Peter Beil - Posts: 19
Hi guys, since a couple of days I am experiencing an odd but disturbing problem:
- I have a workspace set up for various futures markets and I am toggling btw. them with the QuoteBoard
- when I add tools such as lines, rectangles, text etc. and close SC (after saving all) the tools will be there after reopening for all markets (e.g. CL, ES) except for one market, in my case HG
- in this one market (HG) the tools are still there but are all condensed and stacked on one single price
- I have updated SC to Rev. 2408 but the problem remains
What can I do?
[2022-06-28 09:56:52]
Is the symbol of the chart different?:
Is this set to a HG symbol and is the symbol exactly the same as it was when the drawings were drawn?
Otherwise this is not making any sense to us at all. It is a technical impossibility.
Make sure this option is disabled in the Chart Settings for the chart:
Chart Settings: Show Chart Drawings For Different Symbols (Chart >> Chart Settings >> Chart Drawings menu)
Date Time Of Last Edit: 2022-06-28 09:57:22
[2022-07-19 05:51:01]
Hey Guys,
the issue (even it seems from your end technically impossible) persists. I checked your recommendations. As mentioned initially, I use various markets within my chartbook and toggle btw. them by using the quoteboard. The problem never appears for any of the markets other than HG. And it doesn't seem to appear always: in rare cases I restart SC, open the chartbook and the tools would still be there. But in most of the times all tools would be condensed to one price (see screenshot attached). This is really very annoying and I tested all hacks that came to my mind to solve or bypass the problem.
I need your help!
Pete
image2022 07 29 HG Issue.jpg / V - Attached On 2022-07-19 05:42:16 UTC - Size: 661.97 KB - 104 views
[2022-07-19 08:45:06]
Do you know why this would be happening?:
We certainly do not. There is no functionality in Sierra Chart which would cause this.
Is a custom study changing those drawings?
Examine those drawings through the Manage Chart Drawings Window, and see if the properties of them have changed when reopening a Chartbook:
Chart Drawing Tools: Manage Chart Drawings
