Date/Time: Fri, 14 Mar 2025 17:52:53 +0000
Creating a Custom Study
View Count: 346
[2022-06-28 04:14:40]
User486817 - Posts: 83
hello,
i want to put an advanced mathematical equation into (a regression algorithm) into sierra chart as a custom study. i have no experience coding. if i have the equation in C++ will that be sufficient? can ASCIL accept C++ code as-is?
kindest regards,
[2022-06-28 13:47:32]
John - SC Support - Posts: 38669
ACSIL uses C++, but you have to create a proper program and interface with the software in order to get your information into the system. Review the information on creating a custom study here:
How to Build an Advanced Custom Study from Source Code
