Date/Time: Fri, 14 Mar 2025 19:11:07 +0000
ACSIL GetNumLinesUntilFutureIntersection output not constrained to study id
View Count: 361
[2022-06-27 21:41:14]
User145575 - Posts: 20
I am seeing some weird behavior with both sc.GetNumLinesUntilFutureIntersection() and sc.GetStudyLineUntilFutureIntersectionByIndex(). Both accept a StudyID parameter, but when I loop through and look at the individual lines coming back from GetStudyLine...(), I think I'm seeing lines from other studies as well.
In addition, whenever I trigger a study recalculation (either by setting sc.FlagFullRecalculate to 1, or going to the studies modal and clicking "OK"/"Apply", the return value of GetNumLines...() increases by a lot. Way more than I am creating in my own study, anyway (and I programmatically delete those anyway).
Are these known behaviors?
Thank you!
[2022-06-28 09:50:48]
This is 100% impossible:
It is not possible at all. Do not even consider that possibility. It is not possible whatsoever.
They must have been created by your own study. This is the only possibility.
