Date/Time: Fri, 14 Mar 2025 17:58:01 +0000
Trial data and export features
View Count: 419
[2022-06-27 19:20:16]
User144674 - Posts: 3
how much tick data is included with FXCM EURUSD spot data ? I can only see about 186 days, is that true ? Because I read there were over 2 years at least tick data. Second how can I plot a tick chart because I only found to plot a 1 second line chart. Third, how to export tick data, because the data I can export has only a trade every few seconds, do I need to plot Bid-Ask data instead to get more quotes ?
[2022-06-27 19:57:30]
John - SC Support - Posts: 38669
You would have at least 2 years of 1-tick data and then as much as 13 additional years of 4 second data. The actual amount will vary a little bit per symbol.
To get more historical intraday data refer to the following:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data
To get a tick chart, change the Chart >> Chart Settings >> Bar Period >> Bar Period Type to Number of Trades per Bar.
To export the data as it is stored in the file on your system, select Edit >> Export Intraday Data to Text File. Refer to the following:
Edit Menu: Edit >> Export Intraday Data to Text file
[2022-06-27 21:10:10]
Sorry, but when I look on Futures only the actual and last expired contract is available for ES Futures. You say you have tick data available for last years, so why can I open intraday charts from the last two contracts only ? Where do I need to look for more data ?
Date Time Of Last Edit: 2022-06-27 21:25:18
[2022-06-27 21:40:08]
You can enter the symbol name for the past 15 yeaars rather than looking it up. For example, for the ES U contract in 2018, you would enter the symbol ESU18-CME.
Second, you can use the Continuous Futures Contract Chart option. Refer to the following:
Continuous Futures Contract Charts
[2022-06-28 17:45:43]
Can I export 1 second tick data without the millisecond added after the second, because this causes problems when I try to import in MultiCharts. Just the hh:mm:ss, price in that order without the .ms extension. Is that possible, how ?
[2022-06-28 18:37:15]
It is not possible. We export using just the one format.
You can manipulate the data in Excel prior to importing it into another program.
