Date/Time: Tue, 26 Nov 2024 11:22:27 +0000
Market stats do notupdate after upgrade to 1132
View Count: 1044
[2014-05-05 13:49:45] |
User76539 - Posts: 18 |
Hi there, I have upgraded my Sierra to 1132 today and TICK-NYSE[M] is not updating anymore. Can you help me pls.? Thank you mirek |
[2014-05-05 15:48:45] |
Let us know if you are still having a problem with this. It should now be resolved.
[2014-05-05 15:55:33] |
It works now. Thx a lot. mirek |
