Date/Time: Fri, 14 Mar 2025 17:58:01 +0000
Which package for Denali/Teton?
View Count: 901
[2022-06-27 17:15:56] |
cstandfast - Posts: 13 |
Hi SC Looking to migrate from my UK CQG-based broker to either Stage5/Cannon Trading etc in the US using Denali/Teton. Currently on 2393/Pack 10. Trying to work out the correct package number to support this new configuration -- what I can tell, package 10 supports Denali/Teton? It also seems the day-margins for this combo are 10% of exchange initials across all the brokers. Kind Regards -- Colin |
[2022-06-27 17:39:14] |
John - SC Support - Posts: 38669 |
You need to be Package 10 or higher in order to use the Teton Order Routing Service with the Denali data. Since you are already on Package 10, then you should not need to make any change. Once you have setup your connectivity, you will want to update your software to the recent release, just to ensure you have the most recent updates. We can not comment on the day-margins, that is up to the brokers. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-27 17:42:01] |
Thanks John for confirming. Yes, the day-margin thing is one for the brokers, totally agree just mentioned it in case. Cheers -- Colin |
[2022-06-28 18:10:51] |
Stage 5 Trading - Posts: 155 |
Hi Colin, I think you are going to be happy with your decision to move to Teton Order Routing. Stage 5 Trading is a Brokerage firm that has worked hand in hand with Sierra Chart with the implementation of Teton Order Routing. Stage 5 takes great pride in helping traders transition their accounts to Teton Order Routing as seamlessly as possible. In our opinion, to best serve our traders it was prudent to run admin for Teton account setups in house. I believe, this allows us to handle servicing your account in a much more efficient manner as the FCM is rarely needed for intervention. You can open an account for as little as $100 and you will receive $0.20 per side commissions on the micros and $0.45 commissions on non micros plus exchange and regulatory fees. Please feel free to contact us and we will gladly assist you with any questions you may have and/or the process of transitioning your account and hopefully helping you improve your current trading solution. We would be able to provide some DOM chartbook layouts that will hopefully be more in line with what you are accustomed to. In addition, we would be more than happy to have a remote session to help get you setup with the new layouts. If you have questions or would like to speak to an assigned personal broker for details, please call us at 1-312-896-9897 or 1-800-258-6675. You can email us at sierrachart@s5trading.com and can also contact us here: https://stage5trading.com/contact/ If you are ready to move to the Teton Order Routing solution right away, we invite you to complete an application by clicking the blue button at the top of the https://stage5trading.com/ page that says Introducing Sierra Chart Teton Order Routing - Click Here to Open an account Thank you, Anthony Giacomin Stage 5 Trading Trading derivatives carries a high degree of risk, and may not be suitable for all investors. Past performance is not necessarily indicative of future results. |
