Date/Time: Fri, 14 Mar 2025 19:06:43 +0000
Question about volume by price data with denali
View Count: 460
[2022-06-27 15:51:19] |
User265949 - Posts: 2 |
I am currently using the free trial. I am wondering if the denali data package alters the data provided by volume profile by price for Forex pairs. I was also wondering if there is a built in method to calculate intraday percentage of volume above the high volume value area and below the low value area. Thanks! Date Time Of Last Edit: 2022-06-27 15:51:59
[2022-06-27 16:59:30] |
John - SC Support - Posts: 38669 |
We do not understand what you are asking in this. We do not change the data we receive. I was also wondering if there is a built in method to calculate intraday percentage of volume above the high volume value area and below the low value area
There is not a built-in way to do this, but you can output the Volume by Price data with the Spreadsheet and then you could use this to determine the volumes. Refer to the following: Spreadsheet Study Inputs: Output Volume at Price Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-27 18:31:29] |
For the first question I am asking if volume profiles with denali have more accurate information then with the trial? Thanks for the help |
[2022-06-27 19:50:23] |
We are still a bit confused, as you are not using any real-time data from our Denali Exchange Data Feed at this time. If you were using the delayed streaming data during your trial, then that data is exactly the same as the real-time Denali data, as it is the same data, just delayed by 10-15 minutes. But if you were using your trading service data, and you are continuing to use that data, then that is the same data. Although if you were using our delayed data and now are using your trading service data, then that data could be different. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
