Date/Time: Fri, 14 Mar 2025 17:52:53 +0000
Order not at the current price
View Count: 377
[2022-06-27 15:28:10] |
User138457 - Posts: 38 |
Is there a way to set a limit or stop order not at the price that I'm clicking on, but x ticks above (below) it?
[2022-06-27 16:17:08] |
John - SC Support - Posts: 38669 |
You can do this for Stop Limit type orders. Refer to the following: Basic Trading and the Trade Window: Set >> Stop-Limit Order Limit Offset For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-28 10:00:12] |
But not for pure limit or stop orders? stop limit does not really do what I want.
[2022-06-28 10:18:44] |
Have a look at custom trading keyboard shortcuts: Basic Trading and the Trade Window: Custom Trading Keyboard Shortcuts This would be the closest available to what you need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-28 10:18:57
