Date/Time: Fri, 14 Mar 2025 17:52:53 +0000
New Rithmic Issue
View Count: 496
[2022-06-27 13:20:21] |
User28706 - Posts: 23 |
I keep on getting a popup Windows Error 10060. This has never happened before.
[2022-06-27 13:27:02] |
fxzen - Posts: 14 |
Same, seems to be a problem on the Rithmic side, in trying to connect to www.rithmic.com
[2022-06-27 13:42:55] |
NandoB - Posts: 8 |
+1 same issue for me...
[2022-06-27 13:43:59] |
LeDork - Posts: 19 |
Can confirm as well, same issue.
[2022-06-27 13:50:09] |
User12041 - Posts: 25 |
+1 same here.
[2022-06-27 14:58:52] |
We are checking with Rithmic on this.
