Date/Time: Mon, 28 Sep 2026 19:47:21 +0000
[Programming Help] - Setting .Drawstyle is ACSIL Study
View Count: 1986
| [2022-06-27 13:16:51] |
| User92573 - Posts: 617 |
Dear Support I'd be grateful for some direction on the following. Although I set the default .Drawstyle for a Subgraph in the defaults section; I then change the .Drawstyle via the Input Selection i.e. sc.AutoLoop = 1; Subgraph_One.DrawStyle = DRAWSTYLE_STAIR; Input_Show_One.SetYesNo(true); // ------------------------------------------ if(Input_Show_One.GetYesNo()) { Subgraph_One.DrawStyle = DRAWSTYLE_LINE; } else { Subgraph_One.DrawStyle = DRAWSTYLE_HIDDEN; } Here is my issue. I'm now setting on all new bars the selected .Drawstyle which means I cannot now select an alternative .Drawstyle. Each bar will, as expected, run the input question and then set the .Drawstyle to either DRAWSTYLE_LINE or DRAWSTYLE_HIDDEN. As a result other .Drawstyle's are no longer an option, as even if selected they will be reset as the code is executed. I can see a persistent variable is most likely the solution but I'm not sure how to achieve the outcome. Any help appreciated Many thanks |
| [2022-06-27 19:42:08] |
| ForgivingComputers.com - Posts: 1238 |
If you want the user to select any drawstyle, the easiest way to do this on the Subgraph tab of the Study Settings. If you want to limit the user to specific drawstyles, then do it with a Study Setting in ACSIL using .SetCustomInputStrings
| [2022-06-29 06:49:34] |
Thank you.
