Date/Time: Sat, 26 Sep 2026 21:24:29 +0000
DOM Graphics Setting
View Count: 967
| [2022-06-27 09:52:57] |
| countryboy92 - Posts: 119 |
For the labels in my DOM columns, including the symbol title on the left, can I wrap the text of the column headers so they appear on 2 lines instead of going all the way across which is making my columns wider than I would like.
| [2022-06-27 09:53:28] |
The Region Data Line can be set to automatically wrap. Refer to: Chart Settings: Autowrap Chart Header (Chart >> Chart Settings >> Display >> Chart Display Items menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-27 09:53:46
| [2022-06-28 14:38:46] |
Thanks; How can I make the font size smaller for columns other than the current price? Anytime I change the font, it changes for all of them.
| [2022-06-28 15:10:49] |
| John - SC Support - Posts: 48028 |
The font size for all the DOM columns except the Price Ladder is controlled by the font setting for DOM Quantities/Sizes. Refer to the following: Graphics Settings: DOM Quantities/Sizes For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
