Date/Time: Tue, 26 Nov 2024 11:53:20 +0000
CTS SIM
View Count: 1342
[2014-05-05 13:37:03]
User31737 - Posts: 73
I can not connect with my sim account in SC here is the log:
Software version: 1131 | 2014-05-05 08:33:08
Usage end date: 2014-05-31 | 2014-05-05 08:33:08
Enabled for: Advanced Features. | 2014-05-05 08:33:08
Enabled for: Advanced Features 2. | 2014-05-05 08:33:08
Enabled for: Sierra Chart Historical Data Service. | 2014-05-05 08:33:08
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-05-05 08:33:08
Active service: CTS T4 FIX | 2014-05-05 08:33:08
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-05-05 08:33:08
2014-05-05 08:33:08 Local computer clock time | 2014-05-05 08:33:08
2014-05-05 13:33:08 GMT time | 2014-05-05 08:33:08
2014-05-05 08:33:08 Time zone adjusted time | 2014-05-05 08:33:08
Time difference to server time: 0 seconds. | 2014-05-05 08:33:08
Program path: C:\SierraChart\ | 2014-05-05 08:33:08
Data Files path: C:\SierraChart\Data\ | 2014-05-05 08:33:08
OS Version Number: 6.1 | 2014-05-05 08:33:08
Checking for new symbol settings for cts | 2014-05-05 08:33:08
Symbol settings are up-to-date for cts | 2014-05-05 08:33:09
CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2014-05-05 08:33:13
CTS FIX - Firm: CTS | 2014-05-05 08:33:13
Resolved address fix-sim.t4login.com to IP 69.44.110.200 | 2014-05-05 08:33:13
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-05-05 08:33:14
Socket has been shutdown and closed. | 2014-05-05 08:33:14
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-05-05 08:33:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-05-05 08:33:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-05-05 08:33:14
CTS FIX: Disconnected. | 2014-05-05 08:33:14
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-05-05 08:33:14
CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2014-05-05 08:33:17
CTS FIX - Firm: CTS | 2014-05-05 08:33:17
Resolved address fix-sim.t4login.com to IP 69.44.110.200 | 2014-05-05 08:33:17
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-05-05 08:33:18
Socket has been shutdown and closed. | 2014-05-05 08:33:18
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-05-05 08:33:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-05-05 08:33:18
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-05-05 08:33:18
CTS FIX: Disconnected. | 2014-05-05 08:33:18
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-05-05 08:33:18
CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2014-05-05 08:33:21
CTS FIX - Firm: CTS | 2014-05-05 08:33:21
Resolved address fix-sim.t4login.com to IP 69.44.110.200 | 2014-05-05 08:33:21
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-05-05 08:33:22
Socket has been shutdown and closed. | 2014-05-05 08:33:22
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-05-05 08:33:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-05-05 08:33:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-05-05 08:33:22
CTS FIX: Disconnected. | 2014-05-05 08:33:22
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-05-05 08:33:22
CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2014-05-05 08:33:25
CTS FIX - Firm: CTS | 2014-05-05 08:33:25
Resolved address fix-sim.t4login.com to IP 69.44.110.200 | 2014-05-05 08:33:25
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-05-05 08:33:26
Socket has been shutdown and closed. | 2014-05-05 08:33:26
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-05-05 08:33:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-05-05 08:33:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-05-05 08:33:26
CTS FIX: Disconnected. | 2014-05-05 08:33:26
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-05-05 08:33:26
Current selected Data/Trading service: CTS T4 FIX | 2014-05-05 08:33:26
File >> Disconnect selected. | 2014-05-05 08:33:29
CTS FIX: Disconnected. | 2014-05-05 08:33:29
Date Time Of Last Edit: 2014-05-05 14:30:48
[2014-05-05 16:06:31]
This looks like a firewall or other communication problem. These are the relevant messages:
Refer to help topic 1.2:
http://www.sierrachart.com/index.php?l=doc/helpdetails1.html
