Date/Time: Fri, 14 Mar 2025 17:52:53 +0000
Cannot Open Chartbooks on Startup
View Count: 441
[2022-06-26 10:04:59]
User177741 - Posts: 48
Chartbooks that are not directly in the Data folder cannot open on Startup.
For example, if you have a chartbook group... and you add each chart in that group into the Files to Open on Startup... none of those charts will open up when Sierra starts up.
Only if the charts are in the root Data folder then they can startup...
I think this might be a bug.
[2022-06-27 14:34:02]
John - SC Support - Posts: 38669
This is not a bug. The Chartbook Groups are only meant to be opened with File >> Open Chartbook Group.
The idea behind the Chartbook Group is that you would want to switch between multiple Chartbooks, thereby closing the previous group that you had open.
[2022-06-28 07:04:09]
There is no bug here. What you are looking for is just not supported but we will consider adding the functionality.
