Date/Time: Fri, 14 Mar 2025 17:58:01 +0000
Cannot select multiple files for startup
View Count: 444
[2022-06-26 10:02:16] |
User177741 - Posts: 48 |
The checkbox to select multiple files in the file startup selection settings is grayed out and does not work Global Settings > General Settings > [Select Files to Open On Startup] I choose the folder CharbookGroups... then choose the folder with with .cht files in there. The list shows up but I cannot select multiple files!!! I keep having to go reselect the folder... then each file one at a time. I think this is a bug. Thanks Kim |
[2022-06-27 14:27:56] |
John - SC Support - Posts: 38669 |
We will check on whether the multiple selection within Files to Open on Startup can be changed.
[2022-06-27 20:01:56] |
We will have to add support for the two things you are looking for. We will look into this.
[2022-06-27 20:08:51] |
The ability to select multiple chartbooks to open on startup has been added and will be in the next release.
[2022-06-28 01:08:10] |
