Date/Time: Wed, 23 Sep 2026 22:57:54 +0000
Affiliate ID
View Count: 861
[2022-06-26 06:27:56]
User223734 - Posts: 120
I noted the Account Control Board has an item : "Affiliate ID", please advises waht is it?
[2022-06-26 15:47:17]
This is something that is being phased out. It has no relevancy any longer.
[2022-06-27 10:08:32]
I noted my Affiliate ID is "rcorderflow" , can I press "Clear Affilation" to clear it?
[2022-06-27 16:19:05]
John - SC Support - Posts: 47994
You can use the "Clear Affiliation" if you want. The affiliation, in your case, is not used for anything.
[2022-06-27 19:38:42]
It might be used in this particular case. If you know you have no affiliation to them, you can clear it.
