Date/Time: Fri, 14 Mar 2025 17:58:03 +0000
Forex Data on Footprint Chart
View Count: 1281
[2022-06-25 18:53:07]
Connor Ballnger - Posts: 5
Footprint data is displaying extremely low volume data on the footprint chart.
The volume display multiplier is set to 1 and I am using the FXCM data feed.
Is it possible to get more accurate data on forex pairs displayed on the footprint chart?
imageScreenshot 2022-06-25 at 19.50.48.png / V - Attached On 2022-06-25 18:51:07 UTC - Size: 118.65 KB - 189 views
[2022-06-26 23:30:21]
You really need to use Forex futures data for the Numbers Bars study. Use the Delayed Exchange Data Feed:
[2022-06-27 15:29:03]
I am currently on service package 11 - Will this package cover using this feed or will I encounter extra costs?
[2022-06-27 16:21:14]
John - SC Support - Posts: 38669
You can get the delayed data at no extra cost. Otherwise, you will need to pay for the exchange fee, but this can be as little as $1.50, depending on what data you need (the FOREX Futures are part of the CME exchange, so if you do not need Market Depth Data, then you can get the CME Top-of-Book for Non-Professionals for $1.50). Refer to the Setup Instructions at the following link:
