Date/Time: Fri, 14 Mar 2025 14:02:58 +0000
Auto scroll up or down in footprint chart
View Count: 660
[2022-06-24 17:42:51] |
countryboy92 - Posts: 91 |
I have 2 footprint chars that when price moves up or down, the latest candles do not display on the screen and then I have to manually adjust the chart up or down. Is there a way to auto scroll up or down so that the latest candle is on the screen?
[2022-06-24 18:44:41] |
John - SC Support - Posts: 38653 |
It sounds like your Chart Scale Range is set to User Defined, or a Constant Range that does not update with price. You would want to have this set to Automatic or one of the Constant Range options that will update with the last bar. Refer to the information here: Chart Scale and Scale Adjusting: Scale Range (Scale Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
