Date/Time: Sat, 30 Nov 2024 04:54:27 +0000
DOM current traded volume bars
View Count: 1332
[2022-06-24 17:33:46] |
SlothicTrader - Posts: 6 |
Hello, I was long anticipating the ability to turn off the volume numbers in the current traded bid/ask volume of the DOM. Thank you for making that update! I've noticed that after doing this, when opening the chart book the volume bars do not work unless I toggle the hide volume numbers in chart DOM settings on, then back off. Wanted to let you know since it doesn't seem to be working as desired. Thanks! |
[2022-06-27 13:33:25] |
Sierra_Chart Engineering - Posts: 17268 |
We are not able to reproduce this issue on the current version. Update Sierra Chart to the latest version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-27 15:20:28] |
ticinotrader - Posts: 392 |
Dear Support, I've just checked this new function (Hide Volume Numbers From Current Traded Volume Columns). If there are multiple DOMs in a given chartbook, when enabling this option (set to Yes), it will apply to all charts/DOMs in the layout, instead of just the selected one. Can you please make this adjustable on a per-DOM/chart basis similar to other DOM options? Thank you. |
[2022-06-27 22:37:22] |
Thank you for the update. I updated from 2403 to 2408 with the same results. When opening a chartbook the current traded volume is not shown in the DOM until I toggle "hide volume numbers from current traded volume columns" to no. At this point they show up and I toggle back to yes and proceed.
[2022-07-01 20:30:17] |
Sorry about the delay, we will be looking this over today.
[2022-07-03 23:57:26] |
User123179 - Posts: 27 |
Hi Where can I find option to hide current traded bid / ask volume test in DOM ?? This would be incredible |
[2022-07-04 10:46:27] |
Update to the current version: Software Download: Fast Update This is the setting: https://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#HideVolumeNumbersFromCurrentTradedVolumeColumns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-18 20:46:51] |
This has been done: Can you please make this adjustable on a per-DOM/chart basis similar to other DOM options?
We cannot reproduce any issue like this: Thank you for the update. I updated from 2403 to 2408 with the same results. When opening a chartbook the current traded volume is not shown in the DOM until I toggle "hide volume numbers from current traded volume columns" to no. At this point they show up and I toggle back to yes and proceed.
This is now a chart specific option and when it is enabled the numbers do not show but you can show the volume bars instead. Make sure those are displayed: Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns) In newer versions this setting is a little different than shown. Make sure you are running an up-to-date version of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-18 20:47:21
