Date/Time: Fri, 14 Mar 2025 19:06:43 +0000
Undo drawing button skips some
View Count: 474
[2022-06-24 16:15:27] |
MeowthTradez - Posts: 44 |
I don't get how this is supposed to work. sometimes I accidently move something like a fib or parallel lines that I've drawn and want to undo the change but it removes the last drawing I added instead. draw a rectangle accidently move a line press undo instead of undoing the accidental move it removes the rectangle. is this intended or no? |
[2022-06-24 17:09:44] |
John - SC Support - Posts: 38669 |
It goes through each of the actions that has occurred for the drawings in order. We are not able to reproduce a situation where something is skipped. If you can give us specific steps to reproduce, then we can figure out what is occurring. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-28 16:43:13] |
I figured out why this happens. It's because I'm moving a drawing that's copied from another chart. I have a 5 minute and daily chart which copies drawings onto my 1 minute chart If I move a drawing on the 1 minute chart that was originally drawn on the other 2 charts then when I press undo on the 1 minute chart it will undo the last change I've made on the 1 minute chart. I have to go to which ever chart I drew it on to undo it which is kind of weird. Is there a setting to make the drawing history be remembered as a whole instead of individual charts? |
[2022-06-28 17:00:33] |
There is not a setting to do this. It would be something we would need to look into. We have set this as a Feature Request. Just keep in mind that we can not say when we will get to any particular feature. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
