Date/Time: Tue, 22 Sep 2026 03:52:32 +0000
[Programming Help] - volume rofile
View Count: 682
[2022-06-24 13:56:33]
User318521 - Posts: 52
how do i get the low volume areas of a volume profile to have extension lines
[2022-06-24 14:24:09]
John - SC Support - Posts: 47955
There is not an extension line option for "low volume areas". There is, however, extension lines available for Peaks and Valleys, so if you are wanting a low volume that is in a valley, that is available. Refer to the following:
Volume By Price Study: Extend Peaks and Valleys
As a workaround, if you want to mark a particular level, you can use a Horizontal Line drawing tool, or the Horizontal Lines study, whichever may work best for you.
[2022-06-30 19:22:27]
is ther any way to have a horizontal rectangle appear after a three candle pattern with the first days high or low show the gar to the third days high or low? an example in transparent green in pic
imageF.US.MESM22[M] 500 Volume #2 2022-05-20 16_02_34.239.png / V - Attached On 2022-06-30 19:21:28 UTC - Size: 36.42 KB - 191 views
