Date/Time: Sat, 15 Mar 2025 16:00:36 +0000
IBKR: Merger of DTB into the EUREX Exchange
View Count: 686
[2022-06-24 07:49:19] |
Tom_Tom - Posts: 40 |
Hello, yesterday i have get a mail by ibkr that they will merge currently listed products on the DTB into the EUREX Exchange ( Look at the Attached File ). Do you know something about these changes? Can i do something by my own to solve this problem or must i wait until you have implemented this. Sentence from the mail: After the migration, GTC orders will be retained. These orders will show the new exchange name, but remain active. If you are a user of the TWS API, you will be required to send the new exchange name "EUREX" after the product is converted. Regards Thomas |
[2022-06-24 08:05:36] |
We need to do this update on the Sierra Chart side then you need to change all of the relevant symbols that use -DTB within Sierra Chart. Looks like all of the symbols that would be relevant change on July 11 so we will do them the Sunday before. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-24 08:06:13
[2022-06-24 08:08:21] |
Hi, thank you very much for your very fast and nice answer! Regards Tom |
[2022-07-01 12:51:39] |
We have made a note to get this done July 10.
[2022-07-03 10:40:43] |
Sorry for my new post about this issue. But now i have get a further mail by IBKR. IBKR says they will delay the merger roll out schedule. They will communicate new dates in the coming week. Look at the attached file. If i will get new dates, i post it here. VERY MUCH THANKS FOR YOUR PATIENCE! Regards Tom |
[2022-07-03 11:20:37] |
Ok please keep us updated.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-03 11:20:46
[2022-07-08 18:46:38] |
Hello, now i have get a new schedule on merger of DTB and SOFFEX. Please have a look at the attached file. Thanks! Regards Tom |
![]() Attachment Deleted. |
[2022-07-09 03:33:26] |
We have made a note of this. At the time of the change you need to update the symbols in Sierra Chart that are affected, following these instructions: Changing the Symbol of a Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-25 13:54:53] |
We have updated these Symbol Settings and changed -DTB to -EUREX. Follow the instructions here to update the Symbol Settings within Sierra Chart: Global Symbol Settings: Update Global Symbol Settings You also need to update the -DTB to -EUREX for symbols in existing Charts, Trading DOMs and Quote Boards within Sierra Chart. Instructions: Changing the Symbol of a Chart The updated EUREX symbols are listed in File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-25 13:56:39
[2022-07-25 14:51:34] |
Thanks! Works fine!
