Date/Time: Mon, 15 Jun 2026 13:34:26 +0000
Extend horizontal lines from chart across Chart DOM
View Count: 1808
[2022-06-23 22:32:26]
User132992 - Posts: 34
Hello support,
Is there anyway to extend horizontal lines that Ive added to my charts so they run across the chart DOM? Just need a reference point when that thing is going crazy!
Much appreciated,
ND
[2022-06-24 13:14:55]
John - SC Support - Posts: 46674
There is not a way to draw lines in the DOM.
As an alternative, you could use the Horizontal Lines study and put a Value Label or Name Label in the DOM, either in the Price Ladder or in the Label column. Refer to the following:
Chart Studies: Subgraphs Tab >> Name and Value Labels
Date Time Of Last Edit: 2022-06-24 13:15:33
[2022-06-24 13:27:53]
Hi John,
Thanks for your suggestion. Ive been trying to add the horizontal lines study to the chart DOM and all that keeps happening is that I get a study added to the bottom of my main footprint chart (like if you added a volume study) but nothing showing in the lable column of the DOM. I even found this video, which Im following, but I cant seem to get anything to come up on the Chart DOM lable column https://www.ticinotrader.ch/how-to-add-custom-text-labels-to-sierrachart-dom/
What might I be doing wrong?
Much appreciated,
ND
[2022-06-24 14:18:31]
It sounds like you have the Horizontal Lines study going into a separate region (region 2 most likely). Change the region for the study to be in region 1 and then you can do what you want with the labels. Refer to the following:
Chart Studies: Settings and Inputs Tab >> Chart Region
[2022-06-24 15:35:28]
Nailed it! Thanks again John.
Enjoy your weekend pal.
ND
