Date/Time: Fri, 14 Mar 2025 14:01:21 +0000
VBP - Enclosing Outline
View Count: 582
[2022-06-23 21:30:22]
User964846 - Posts: 38
Hello, SC! There is a setting in VBP, called Volume Profile Enclosing Outline (SG17). I figured it would trace the Profile, but instead it is tracing the entire visible chart window. I assume its not supposed to just encircle the window, so I've probably set something up wrong. Can you help?
[2022-06-24 05:39:00]
The enclosing outline is going to draw a box around all of the bars which are part of the Volume Profile.
[2022-06-24 13:28:42]
John - SC Support - Posts: 38653
If you want to see just the outline of the profile, then set the Volume Bars Draw Method to Hologram. Refer to the following:
Volume By Price Study: Volume Bars Draw Method
