Date/Time: Sun, 08 Sep 2024 00:24:45 +0000
Rithmic spread format for NYBOT
View Count: 1233
[2014-05-05 10:08:40] |
VF56002 - Posts: 27 |
Hello, I cannot find correct format for spread symbols traded on NYBOT. For example Sugar contract is in following format: SB FMN0014!-NYBOT in "Find Symbol" list I tried: - SBN4-SBV4-NYBOT ( error: Symbol unknown) - SB FMN0014!-SB FMV0014!-NYBOT (no error but no market depth and no last price available) Other markets like CLU4-CLV4-NYMEX, SMN4-SMQ4-CBOT work flawlessly Thanks for help |
[2014-05-05 15:53:10] |
Make sure you have 2 space characters after each SB in the symbol. Does the Rithmic R|Trader software list the spread symbols for ICE? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-05 15:53:33
[2014-05-05 16:37:16] |
Just installed Rithmic R|Trader demo as you mentioned and found the correct format for NYBOT: SB FMN0014-SB FMV0014-NYBOT is correct with two whitespaces Thanks for the hint |
