Date/Time: Fri, 14 Mar 2025 13:58:11 +0000
Data issues
View Count: 453
[2022-06-23 12:31:58] |
pismo10 - Posts: 164 |
DTN for years, now this morning nothing. Trying to switch to SC data. Need ES, MES real time. Switch from 5 to 11, no help. Getting nothing, been thru "instructions" a dozen times, still nothing.
[2022-06-23 12:58:31] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. We just need to know one symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-23 14:29:44] |
Got DTN working again.
