Date/Time: Mon, 05 Oct 2026 01:29:43 +0000
chartbook
View Count: 838
| [2022-06-23 04:10:24] |
| User411320 - Posts: 379 |
hello, I'm getting the following message when opening a chartbook "The Chartbook file is not a valid Chartbook. File: C:\SierraChart\Data\nextSignals.Cht | 2022-06-22 18:25:22.784 * " what am i doing wrong ? |
| [2022-06-23 07:38:08] |
Attach the Chartbook file here and we will convert it for you to the new format. Instructions: Support Board Posting Information: Attaching a File (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-06-23 18:51:38] |
attached is the chartbook thanks
| Attachment Deleted. |
| [2022-06-23 18:59:04] |
| John - SC Support - Posts: 48095 |
Here is the converted file.
