Date/Time: Thu, 28 Mar 2024 15:20:48 +0000
[User Discussion] - Custom study syntax help needed
View Count: 1792
[2013-04-27 00:48:27] |
User22396 - Posts: 191 |
Going way out on a limb here in tryin to modify some of Kiwi's older code for the AverageRange study from kiwi8.cpp...thanks kiwi! Tryin to find the 'Minimum' of these 2 expressions... A) sg.Subgraph[2]=sg.BaseDataIn[SC_HIGH][i-j]-sg.BaseDataIn[SC_OPEN][i-j] B) sg.Subgraph[2]=sg.BaseDataIn[SC_OPEN][i-j]-sg.BaseDataIn[SC_LOW][i-j] In a spreadsheet study would just be Min(a,b) so wasn't sure if it that easy to re-code? somehow I do not think so lol I was able to create 2 new studies using A OR B above and compile with no errors but not sure how to find the minimum of both expressions in just one study Thanks B Date Time Of Last Edit: 2013-04-27 00:48:45
[2013-04-27 01:13:03] |
would this work? if(sg.BaseDataIn[SC_HIGH][i-j]-sg.BaseDataIn[SC_OPEN][i-j]> sg.BaseDataIn[SC_OPEN][i-j]-sg.BaseDataIn[SC_LOW][i-j]) = sg.Subgraph[2]=sg.BaseDataIn[SC_OPEN][i-j]-sg.BaseDataIn[SC_LOW][i-j]; else sg.Subgraph[2]=sg.BaseDataIn[SC_HIGH][i-j]-sg.BaseDataIn[SC_OPEN][i-j]; |
[2013-04-27 01:29:22] |
ejtrader - Posts: 688 |
Don't know what exactly you are trying to do - but you can try this and see: sg.Subgraph[2][i]=min( (sg.BaseDataIn[SC_HIGH][i-j]-sg.BaseDataIn[SC_OPEN][i-j]), (sg.BaseDataIn[SC_OPEN][i-j]-sg.BaseDataIn[SC_LOW][i-j]) );
Date Time Of Last Edit: 2013-04-27 01:30:13
[2013-04-27 03:11:12] |
Thanks ejtrader!...compiled fine...goin check to see if outputting correctly I am trying to recreate an indicator I have used in NT7 that plots the AverageDailyNoise (i.e. 10day sma of ADN etc) as bands around an 'Open' price (i.e. globex or pit etc)...similar to OR breakout |
