Date/Time: Fri, 14 Mar 2025 14:01:22 +0000
Extend drawings not saving as default
View Count: 361
[2022-06-21 18:19:49]
MeowthTradez - Posts: 44
I'm trying to make parallels lines and regular lines drawings extend by default but they aren't saving that way. Is this a bug? It saves width and color but doesn't save the extend forward setting
[2022-06-21 18:56:56]
John - SC Support - Posts: 38653
The reason why you can not save the extended lines and parallel lines is because when they are extended they are Rays and Parallel Rays. Therefore, you would want to modify and use the ray options instead.
