Date/Time: Fri, 14 Mar 2025 14:02:58 +0000
Custom Color Transparency missing SUGGESTION
View Count: 416
[2022-06-21 17:24:05] |
jakeybleez - Posts: 56 |
hello! i was really surprised when i noticed the custom color creation window has no "transparency" option. this is a very simple but key component when i am picking colors for my chartbook. setting transparency on certain things and not others really helps what you truly need to see POP. for now i am just making the colors darker and it's ruining the idea/potential forsure. just figured i would give you guy's a headsup, i absolutely love your software and how great your team is. i am a proud Sierra Chart user that's forsure and i'll never leave haha thanks so much |
[2022-06-21 18:29:11] |
John - SC Support - Posts: 38653 |
Transparencies are not controlled by the colors, but rather through the Draw Style. Refer to the information here: Chart Studies: Using Transparency For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
