Date/Time: Fri, 14 Mar 2025 14:02:56 +0000
Initial Balance width on market profile
View Count: 494
[2022-06-21 07:49:03]
Mustang77 - Posts: 122
Hi
The initial balance on the market profile is shown by a vertical bar.
How cai make that bar thicker or wider ? so that its more visible.
I cant find the setting
Thank you
[2022-06-21 13:55:31]
John - SC Support - Posts: 38653
There is not a setting to change the width of the Initial Balance vertical bar. The bar is drawn based on the width of the bars. So the only way to see it better is to expand the time scale (increase the bar spacing).
