Date/Time: Fri, 14 Mar 2025 14:01:18 +0000
older unnecessary data re-downloaded after loading a chart using date range
View Count: 407
[2022-06-20 20:24:56] |
Rnn - Posts: 56 |
Hi, I loaded a chart between some months from last year and much older .scid files were re-downloaded - for example ESU16 / ESZ16 also 17,18,19,20 how do I prevent it from downloading the unnecessary older data? |
[2022-06-20 20:40:45] |
John - SC Support - Posts: 38653 |
It should only be downloading the data for the range of dates for which you need the data. Check to ensure that you do not have another chart that is requesting information going back to 2016.
[2022-06-20 21:46:52] |
Rnn - Posts: 56 |
how can i check if there's some hidden request for that data cause i don't have any chart loaded from that older range
[2022-06-21 09:36:51] |
We need to know what the Chart Settings are for that chart. Attach it by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart We doubt there is a problem. There must be a chart, which is including those particular contract months and years. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-21 09:37:09
