Date/Time: Fri, 14 Mar 2025 14:02:56 +0000
Euro future sep contract sim
View Count: 525
[2022-06-20 12:26:09]
MUSE SABRIE - Posts: 4
It shows different data can you fix
[2022-06-20 15:10:12]
John - SC Support - Posts: 38653
What specific symbol are you having an issue with, and what is the exact problem with the data?
Keep in mind you are using our Delayed Streaming data feed, so the data is going to be about 15 minutes behind the real-time data.
[2022-06-21 06:47:37]
No it’s shows days behind not 15min euro future sep contract please can you check it
[2022-06-21 13:51:55]
We need to know the exact symbol you have entered for which you are having an issue. The problem could be the way the symbol is entered or the particular data you are looking for. Please let us know the symbol you have entered.
[2022-06-21 15:20:27]
6EU22-CME
[2022-06-21 15:36:49]
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2022-06-22 10:49:57]
I think we have I misunderstanding, I don’t have problem using chart, everything is ok except pricing is shows wrong pricing and is not delay, I know what is delay mean because I have using sierra chart for two month, the problem I have is from you side because you printing wrong pricing, if you check 6EU22 delay data you will see what I am talking about.
Thanks again
[2022-06-22 10:52:03]
In your case the data for that symbol is going to be 10 minutes delayed. Is that what you expect?
