Date/Time: Fri, 14 Mar 2025 09:51:29 +0000
big problems sierra chart hangs with rithmic
View Count: 377
[2022-06-20 12:07:33] |
User944729 - Posts: 1 |
Hi, Since Friday I've been trying to connect my Leeloo account with sierra chart, I've tried everything possible and also booked the denali data feed again, unfortunately as soon as I connect to the datafeed the whole software hangs (functions, execution, everything) what can it be and I really urgently ask for help. Thank you so much |
[2022-06-20 12:14:57] |
Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.48 - Basic Steps to Resolve Performance Issue in Sierra Chart First thing we recommend you do is start with Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
