Date/Time: Fri, 14 Mar 2025 07:01:06 +0000
Constant Scale settings, in new version
View Count: 427
[2022-06-19 21:24:31]
KylieV1618 - Posts: 67
I downloaded the latest version but I can't find the constant scale settings anymore.
I need the price to re-center automatically. How can I activate this in the new settings screen??
[2022-06-19 22:23:39]
58LesPaul - Posts: 429
Are you referring to this Constant Range? If so, just right click in the price column and select scale settings.
imageSierra Chart 2400 ES 60-15-5 SC Data - All Services 2022-06.png / V - Attached On 2022-06-19 22:22:17 UTC - Size: 31.19 KB - 120 views
[2022-06-20 07:31:18]
Follow the instructions here for this:
Chart Scale and Scale Adjusting: Opening the Scale Settings Window for the Main Price Graph
