Date/Time: Fri, 14 Mar 2025 09:46:07 +0000
any plan to add stocks and ETF brokers
View Count: 462
[2022-06-19 17:56:24] |
User396 - Posts: 55 |
i would like to know if SC has any plan to add any broker who support stocks and ETF like tradier, TD ameritrade, Alpaca who can offer API for trading thank you, bhupen |
[2022-06-20 07:33:28] |
No, not at this time. We are looking into other options for stock trading but it would not involve those brokerages.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-20 07:33:41
