Date/Time: Fri, 14 Mar 2025 04:21:17 +0000
Total Volume for SOXL TotalView
View Count: 405
[2022-06-19 14:25:00] |
User396 - Posts: 55 |
total volume shown for NASDAQ symbols are quite lower than reported by other vendors. for example, total volume for SOXL-NQTV on 6/19, SC reports 5.15 m volume vs tradestation and tradingview ~ 64.01 m. Would this affect my studies? is that because i am on delayed quotes? in other words, can this discrepancy be fixed if i subscribe to "NASDAQ US Data"? than you, bhupen |
[2022-06-20 06:19:47] |
This is answered in this particular section here: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes It is not related to delayed data. You will see the full volume when using the symbol SOXL. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-20 06:20:31
