Date/Time: Fri, 14 Mar 2025 09:46:08 +0000
Default MNQ session times are different from NQ, ES, and MES
View Count: 696
[2022-06-18 18:42:59] |
sean3000 - Posts: 65 |
The default session times for NQ, ES, and MES are: 09:30:00 16:14:59 [Evening session enabled] 16:15:00 09:29:59 The default session times for MNQ are: 18:00:00 17:59:59 [Evening session disabled] 00:00:00 23:59:59 Is there a reason MNQ is different than the other index futures? I'm planning to change the symbol settings manually but wanted to make sure I'm not missing something. |
[2022-06-18 20:10:56] |
We will check on this.
[2022-06-18 20:13:12] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
