Date/Time: Fri, 14 Mar 2025 07:01:06 +0000
Background Coloring Method based on "AskVol BidVol Difference - Percentage"
View Count: 687
[2022-06-18 18:33:34]
User424964 - Posts: 2
Hello, I'm really interested in the platform but I'm struggling configuring the template I need cause I would like to have a new method for the background coloring of Number Bars study. I already used the "Background Coloring Based on AskVol BidVol Difference Percentage of Max Dominant Side" but it's not good for my goal.
I already programmed a simple software to calculate the numbers of the ranges to use with the existent "AskVol BidVol Difference - Actual", but I would like to have this new option so number bars value will auto-configurate every day.
My idea basically is to calculate the "AskVol BidVol Difference" colors based on a custom percentage values, analyzing the previous day (so it will adapt to lighter or heavier volume period of the market); for example: Range0: Custom value 1 of (Average of everybar Delta), Range1: Custom value 2 of (Average of everybar Delta).
I would REALLY appreciate this, cause this platform would be perfect.
Thank you in advance.
Date Time Of Last Edit: 2022-06-18 18:35:22
[2022-06-19 13:26:41]
Nevermind, just solved using ACSIL.
Thank you for your great and malleable platform!
