Date/Time: Fri, 14 Mar 2025 19:06:43 +0000
Inverted Charts - Calc tool & Fibo Tools do not properly calculate distances
View Count: 525
[2022-06-18 01:47:05]
HumblyTrading - Posts: 192
Hello SC Team,
I'm not sure if this is already known, but there is an issue when using inverted charts, measurement tools such as the calc tool and Fibo Retracement Tools no longer calculated distance in pips correctly.
I am testing this on GBPUSD and USDX.
Please consider making the calc, fibo and other tool distance calculations in tics/points compatible with inverted charts.
Thank you
Mike
[2022-06-21 06:41:55]
https://www.sierrachart.com/image.php?Image=1655793607720.png
Here is an example of how the Fibonacci Tool fails to calculate when using inverted charts.
This is USDX inverted.
Can this be fixed?
Thanks!
Mike
[2022-06-24 20:01:53]
Hello SierraChart Team,
I am wondering if this issue may be addressed, or if perhaps I am doing something incorrectly?
Any help would be appreciated.
Thank you,
Mike T
[2022-06-27 17:53:29]
Hello SC Team,
Is there a workaround to get distances measured on an inverted chart?
Mike T
