Date/Time: Fri, 14 Mar 2025 07:01:06 +0000
Customize keyboard shortcut
View Count: 601
[2022-06-17 22:16:32]
User510097 - Posts: 4
I have a on/off button on my control bar which is "ASCI - turn auto strategy on/off". I would like to have a keyboard shortcut which will do the same. When I look under "global settings" and "customize keyboard shortcuts" I do not see an option "ASCI - turn auto strategy on/off". And when I try the shortcut "Auto trading enabled chart" or "enabled global", this does not turn on/off my auto strategy. How do I create a keyboard shortcut for "ASCI - turn auto strategy on/off"? Thank you
[2022-06-18 13:51:02]
ForgivingComputers.com - Posts: 1021
The Command you are looking for is "Custom StudyControl Bar Button Keyboard Shortcuts". Make sure it matched the number of the Control Bar Button.
[2022-06-18 15:18:55]
thank you so much, that did it!
