Date/Time: Fri, 14 Mar 2025 09:44:22 +0000
loading Charts
View Count: 420
[2022-06-17 19:15:58] |
Gasoil - Posts: 18 |
i would like to ask something that probably i,m missing. So i know that your platform is fast and i can see that for myself my problem is that when i,m using sierra charts for forex and i want to fast change from one time frame to another the settings are limited to days to load and for example if i,m trying to see a 1 min chart and it loads 30 days that's enough but when i change to a 4 H charts the same 30 days loaded is not enough forcing me to have more that one chart open at anytime which one with specific days to load to serve time frame needs.Is there a way to have like tradingview that loads bars instead of days? so for instance if i load a 1 min chart and loads 10K bars that will be equivalent to 3 mouths but if i load a 4 H chart thal will be 2 or 3 years. but my question is there a way in your platform that i can go around this that i,m not aware thank you.
[2022-06-17 19:37:09] |
John - SC Support - Posts: 38653 |
There is not a built-in way to do what you are asking for. It is possible to make this work, but it would require creating a custom study that would check the timeframe of the chart and then set the days to load based on what you want. Refer to the information for our interface at the following link: Advanced Custom Study Interface and Language (ACSIL): Introduction Or you can find a developer to do this for you. We have a list of developers at the following link: List of Third Party Sierra Chart Study and System Programmers And finally, there is a user named "Ackin" that has a lot of free studies that he has developed, and he might have something like this already. If you do a search for his name you should find a post called "Ackin's Indicators" in which you can contact him and see if he has this or could develop it for you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-17 20:08:09] |
Thanks again for the fast reply the service you provide speaks for itself and I will have a look at the third party programmers
