Date/Time: Tue, 22 Apr 2025 23:11:27 +0000
Saved Trade Activity Log import problem
View Count: 911
[2022-06-17 18:51:12] |
User163134 - Posts: 5 |
Hi, How can I import Trade Activity Log which was saved in an older version of SC? I only can import which was saved with the current version of SC but I unable to import a month old log file. Is there any trick for it? Thanks |
[2022-06-17 19:02:19] |
John - SC Support - Posts: 39428 |
Is there any information in your Message Log as to why the file will not import? If so, then please put that information into this thread for us to take a look. Or try to do the import, then copy and paste your entire Message Log into this thread for us to see if there is specific information.
[2022-06-18 18:51:49] |
Reading Internal Order ID file. | 2022-06-18 20:44:28.776 Reading Trade Orders file. | 2022-06-18 20:44:28.934 Reading Trade Positions file. | 2022-06-18 20:44:28.935 Reading Trade Account Data files. | 2022-06-18 20:44:28.935 UDPListener (1540). Port 22904 | Listening on UDP port 22904. | 2022-06-18 20:44:28.958 Software version: 2389 64-bit | 2022-06-18 20:44:28.959 Importing Trade Activity from the file P:\Trading\Sierra Chart\SavedTradeActivity\2351\TradeActivityLogExport_2022-06-14.txt | 2022-06-18 20:47:34.194 Date Time Of Last Edit: 2022-06-21 22:16:12
[2022-06-18 18:56:37] |
It seems to me nothing's wrong but the Trade Activity Log window stays empty.
[2022-06-18 20:14:11] |
One thing to be aware of is that you can only import order fills. It is only possible to export and import order fills. Not any other trade activity.
[2022-06-18 20:36:30] |
I did downgrade the SC to the version of 2351 then did the export... cleared the trade activity log... upgraded to the 2389... tried to import without success. I got back nothing. Not even a bit of info. I did downgrade again to the version of 2351 and imported the trade activity log and I got my whole trade activity back. Why can't I import trade activity log saved via older version of SC into a newer one? |
[2022-06-21 11:47:56] |
We will check on this and see what the issue is.
[2022-06-22 10:29:22] |
This is now resolved in version 2404. This is the prerelease. Update instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-22 10:29:57
[2022-06-23 08:06:55] |
Thank you!
[2022-09-01 01:01:52] |
User353062 - Posts: 32 |
There is a problem with trade activity log. When I'm done trading, it show all detail correctly in the trade activity log. Then I have saved it for the day. When I import it back into trade activity log, it does not show the correct time. The trade list and everything is there. The only problem is the timestamp of actual trade was wrong. It does not show on my chart. Is there a way to fix this?
[2022-09-01 16:11:16] |
There are two ways to save the Trade Activity Log. One is using File >> Save Log As and the other is to use File >> Export. When you use Save Log As, it saves the time for the entries as you see them on the screen. When you use the Export option it saves the times in UTC. When importing the data, we expect the information to be in UTC time, and then we do the conversion from that time to the time zone you have set in your software. As such, if you intend to re-import the data, you need to use the Export option. Refer to the information at the following two links for these options: Trade Activity Log: Importing and Exporting Data Trade Activity Log: Saving to a Text File For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-20 14:19:24] |
StephenL - Posts: 120 |
Hi guys, Im having trouble getting an imported trade to show as a fill on the chart. The bottom 2 rows are the trade that wont show on the chart. The upper two rows are a trade I took through the chart DOM and shows up fine. Are you able to see a difference between the two trade entries that may cause this issue? Thanks Addition: Does the ClientOrderID have to be unique for each trade across all markets? Date Time Of Last Edit: 2023-03-20 14:21:31
[2023-03-21 16:49:16] |
Sierra_Chart Engineering - Posts: 19305 |
Check the Trade Account. Most likely that is where the problem is but we cannot see it in the screenshot. The client order ID is not even required at all. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-21 16:49:32
[2023-03-21 17:45:45] |
I checked and the Trade Account is the same. I'll give more color, I have two trading platforms, Sierra Chart and another. Im trying to import my trades from the other software so I can get the fills from both on the same chart. So I have put the other platforms fills in the exact same format txt file as Sierra Chart and imported but they won't appear on the chart. I have made up a number for InternalOrderID, ServiceOrderID and FillExecutionServiceID and have correctly formatted the Open/Close and Internal Position boxes to be correct. I must be either missing something, or this is not doable, please let me know? Thanks P.S. for what its worth Sierra Chart is a brilliant package and I should have moved sooner, you've built an amazing piece of software (well done). Ill be phasing out the other trading software but in the mean time if I can find a way to put both sets of fills on the same chart my review days would be very much shortened. |
[2023-03-21 22:05:06] |
Make sure you do an Export of your Trade Activity Log first and then modify that file with the information from your other trading system. Then import that back. This will ensure it is in the correct format. Also make sure you have a blank line at the end, the same way as when it is exported. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-23 10:23:49] |
Yea that worked perfect, thanks very much for the help.
