Date/Time: Fri, 14 Mar 2025 07:01:07 +0000
CQG
View Count: 436
[2022-06-17 16:47:20]
User826539 - Posts: 18
Hi There,
I hope you are well.
I am about to sign on with a firm but the only Sierra compatible data feed they offer is CQG. I have noticed that sierra are no longer planning to support CQG. My entire system is built on Sierra, will CQG routing be supported going forward?
Any information is much appreciated.
[2022-06-17 17:11:58]
John - SC Support - Posts: 38653
We still support, and expect to continue to support the CQG order routing. It is just the data from the CME Group and EUREX that we are no longer allowing into the system.
We see you are already using our Denali Exchange Data Feed, so you will be fine using CQG for your order routing with our Denali data.
[2022-06-20 10:24:16]
Is there any documentation for running market data from one source (Denali) and routing through another (CQG)? I am thinking especially of price ladders/DOMS. Thank you
[2022-06-20 10:54:26]
Yes this is fully documented here:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
It is very simple with how this works.
