Date/Time: Fri, 14 Mar 2025 07:07:17 +0000
chart not showing date beyond specific date
View Count: 386
[2022-06-17 16:43:50] |
shelspeare - Posts: 1 |
Dear Helpdesk, I have issues updating the charts with current date or beyond a specific date. For some reasons, the loaded chart shows up to May 31 only. I have disconnected and re connect data feed but no result. Can you please help? Thank you very much Regards |
[2022-06-17 17:09:59] |
John - SC Support - Posts: 38653 |
Are you having problems with all charts or just certain symbols? If only specific symbols, then which ones? For one of the charts in which you are having the issue, please go to Chart >> Chart Settings >> Data Limiting and check if your Load Data Limiting Method is set to Use Date Range and if so, then what are the Date Range From and Date Range To entries set to. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
